- Joined
- 2 Jul 2018
- Messages
- 14
- Reaction score
- 1
- Country
Hi there. I’m looking to replace our existing Aqualisa Colt shower with a new shower from IKEA. I thought it was going to be a simple replacement job but I’ve discovered they’re fitted in different ways.
Our existing shower fits on with its own bracket and plastic ends just slip directly on to the copper pipes whereas our new IKEA one fits on like most thermostatic shower valves, using a shower fixing kit with a compression fitting.
The issue I’m having is that when using the shower fixing kit I don’t have much copper pipe protruding from the wall bracket holes so I can only just get the olive onto the pipe, there’s probably a 1mm overhang. I assume this is what is causing a leak when I try and hook it all up?
Does anybody know of a solution to my problem other than stripping the wall back and starting again? Are there different types of fixing kits that might work? Can a plumber extend the pipes? Could I cut down the pipes at the floor and connect plastic flexible pipes to the copper pipe and use this instead?
Any help appreciated, thanks!
Alternatively if anybody knows of any other showers that connect like our existing one, other than the new version of the Aqualisa Colt, please let me know!
