- Joined
- 25 Apr 2016
- Messages
- 2,890
- Reaction score
- 721
- Country
Heat exchanging extractor fan?
One that runs more or less permanently...
Agree, we got one cheap, but at full price it would cost a lot more than a piv. The energy savings themselves are not worth it but it provides a nice environment.Heat exchanging extractor fan?
Washing line no use in winter
For your information i have had a survey done by an expert and i am acting on his recommendations guess i must be a good landlord after allOf course it is. What family does not dry their clothes on an airer inside the house?
People have always done it, and always will. The fact that modern houses have radiators and central heating, means that its done more frequently, and potentially in more or different rooms.
If the house that you let can't deal with that, then that's the problem not the people living in it - just doing things that everyone else does ..... aka modern living.
The first sign of a bad landlord is blaming the tenants. Yes there is a duty for any tenant to act in a "tenant-like manner", but that does not negate the landlords responsibilities to deal with inherent problems with a property.
You say that you have insulated the cavity walls as if to proclaim that that is it, you've done your bit and the damp should stop. In fact, you may well have exhasperated the problem. Did you have the issues diagnosed? Did you have a proper expert survey report identifying the issues and recommending a solution? I strongly suspect not. A good landlord would have.
Have you?For your information i have had a survey done by an expert
For your information i have had a survey done by an expert and i am acting on his recommendations guess i must be a good landlord after all![]()
