- Joined
- 6 Nov 2008
- Messages
- 830
- Reaction score
- 16
- Country
We have a one door contact that is connected to a zone in the panel.
I have set the system. Everything works except the contact.
Is this wired incorrectly?
Is it showing a fault or clear but not activating ? If fault remove green and white at the contact , twist the bare ends together , does it clear the fault ?
It could be, but, without seeing the other end of the cable... we don't know!
The two middle screws are the lid tamper contact. One would 'normally' expect the blue/yellow pair to be wired through this contact to implement tamper protection. However, since these are joined together & placed under the end screw, this is not your issue.
IHMO the quality of the wire stripping & termination is poor but they do seem to be connected.
Remove the green wire from the contact ....does it show a fault now ?
