How intriguing - I can't for the life of me understand how that happened - I've now corrected it, anyway!I am quoted but I have never written on this thread.
I am told there were quite a few prosecutions pre-war, but that is before my time, since I have been alive we have only had one meter for both lighting and power.Against the law? Did enforcers visit to check?
As been mentioned current will not run through the light switches only through the ceiling roses . If using modern ceiling roses and 1.5mm cable then installing a socket up there on the lighting circuit and leaving the mcb at 6A will do no harm. It is electrically sound. How often will you draw more than 6A from this socket? And how often? 6A is a lot. Only the likes of kettles exceed that. A 1 kW fan heater would work OK. The socket probably would be used for power tools and the likes. 1.5mm is rated at approx 15A max current. Ref 100 says 16A.Because threads on this topic usually descend into a long winded unhelpful argument, I've not really paid much attention to them, I usually just skim through them, but...
Assuming the circuit is 1.5mm² and assuming you have "reference method 100" or better, can't you just stick a B16 in the consumer unit and then have your single socket in the loft, without fear of anything bad happening at all, even when you for 'some reason' decide to take a kettle up in the loft?!?! (not that I agree with that stance/reasoning anyway)
Am I missing something obvious/prohibitive here?
The reason I fear I am missing something obvious, is, how come this doesn't seem to get suggested in those threads, if this is, indeed, perfectly fine to do?
Not really, they are both the same if used for the loop. The ceiling rose just doesn't have a switch.As been mentioned current will not run through the light switches only through the ceiling roses .
We all know that. There is just one poster (missing at the moment) who will not stop saying it is not.If using modern ceiling roses and 1.5mm cable then installing a socket up there on the lighting circuit and leaving the mcb at 6A will do no harm.
Method C - 1mm² T&E is 16A and 1.5mm² 20A.1.5mm is rated at approx 15A max current. Ref 100 says 16A.
So would 1mm² T&E but for some reason not allowed on "power circuits" but then call it a "lighting circuit" and all is well.In my last house I removed the upstairs ceiling roses (cables in the loft) installing 20A 4 terminal J boxes for LED downlighters. So using the diversity factor, 1.5mm is fine with a single 13A socket and a 16A mcb on it.
That has nothing to do with whether you can have a socket on a 6A circuit or why it could not be 16A.One of the reasons lighting is on a different circuit is so that if there is a power fault, the lights are still on. Divide and rule is the way.
I don't think it's up to you to order people not to do something perfectly normal and which meets the regulations. Get a sense of proportion!Don't do it.
Even winston has not suggested that anyone would feed a vacuum cleaner through a light switch!
It was, but that was 60 years ago. When she abandoned the one that she previously had heated up on her gas stove and moved on to an electric iron, my grandmother used to plug the electric iron into a bayonet adapter - and that was probably at least 1kW (and that practice of hers persisted well into the 60s).It was often done back in the '50s. Two pin 5a plug on the vacuum cleaner plugged into the light via a bayonet adapter. But vacuum cleaners were not 2kW loads back then.
It's in the regs. It's allowable.I would not call it perfectly normal.
I'm so glad this thread did not decend into an argument.![]()
Jolly good question. From their appearance, I would think that either could probably happily carry at least 20A-30A, quite probably more!While we're on the subject, what is it about a 2A or 5A plugs that is limits them to 2A or 5A? The pins aren't tiny and neither are the terminals.
