Wiring a light
2 Nov 2008
Manchester
hello.
Replacing old light with new. I understand the neutrals go to neutrals and the switch live goes to the light and the other 3 go into a block on their own. I’ve check the other lights in the house and they are wired exactly like this.
The light won’t come on.
What am I doing wrong?
Thank you
https://pasteboard.co/HzMMYzb.jpg
Are ALL of the other lights working correctly?
Are you certain the black with the red sleeve WAS sleeved red before you started?
Any broken or loose wires?
Have you done any other electrical work recently?
Is there a fuse or breaker somewhere isolated?
All sorted.
I had to combine the switch wire with the other two red lives wires and it’s all working as it should. Thanks for your reply.
All sorted.
Your picture shows the red of the switch cable 'combined' with the other two reds.
This makes no sense.
1) All the reds needed to be connected together.
2) You had all the reds connected together:
3) You said "I had to combine the switch wire with the other two red lives wires and it’s all working as it should", i.e. you said "I had to connect all the reds together like I already had and it’s all working as it should."
4) When sparkwright said "Your picture shows the red of the switch cable 'combined' with the other two reds" you said "Yeah, this is where I was going wrong".
In other words when it was pointed out that you had right from the start done what you said needed to be done, you said that doing right from the start what you said needed to be done was where you were going wrong. o_O
Those earth conductors must be connected together.
