I plan to buy a Nest thermostat, but because I dont have any 12v supply wires to the control box, I need to power the thermostat separately.
I dont like the USB PSU and Cable solution because it means the USB wires will be visible running up the side of the wall. I would much prefer the power supply to be hidden in the studwork itself.
Notwithstanding some folk wont like the idea of hiding a PSU in studwork, I was wondering if anyone had managed it?
i.e. A metal single-gang dry lining box, with a 230v to 12v PSU connected inside. The box can be covered over with a blanking plate. I can then run the 12v wires into the back of the Nest thermostat which should look far neater.
Has anyone done anything similar, and if so is it possible to purchase a 12v PSU which can fit into a single-gang dry lining box? (it would be ideal if such a part already existed).
Cheers in advance.
Cheers in advance.
