Hello,
While cleaning out my gutters the other day, just after it had rained, I noticed that the end of my breathable membrane was saturated. I can't see a lot of it, but because I have double roman tiles you can see between the raised parts of the tile. The roof is not leaking, its just the angle of the rain hitting the membrane. Also like the majority of roofs I don't have any eaves protectors.
At the time I didn't think much of it, but thinking about it later it occurred to me that if the membrane can soak up water then couldn't it soak water back far enough to get beyond the fascia board and affect the timbers?
So yesterday when the membrane was dry I poured some water on the edge of it with a watering can and it does indeed soak up water. You could see the water creeping up the membrane.
So my question is, isn't this bad? Can it really soak water back far enough to cause problems? Is this a known issue with breathable membranes?
Something seems wrong here to me.
Any thoughts most appreciated.
Thanks,
Bob
Thanks,
Bob
