- Joined
- 27 Jan 2008
- Messages
- 28,984
- Reaction score
- 3,552
- Location
- Country
I am sure there is a formula, engine max torque, gear, transfer box, and axles ratios, and wheel size, one would need then to allow some leeway so maybe using the old 2πNT/33,000 to get the torque at max BHP which would be lower.
However the spec sheets seem to show speed at 1000 rpm, this should allow for tyre size, as saying it has 17" wheels does not help as that is not the tyre size.
So I suspect there will be a number x speed at 1000 RPM x BHP = pounds pull. Then some trigonometry formula that needs car + caravan weight and the pounds pull and will give you the incline that it will climb.
So if the result = 1 in 8 then I will know anything more than 1 in 10 needs avoiding. And if 1 in 2.5 then I can pull caravan up any UK road, as 1 in 3 is the steepest. 1 in 4 on a major road (Sutton Bank) and there are quite a few 1 in 6 hills.
I have used a 62 BHP car to tow a 14 foot caravan up Sutton bank, Curb car weight estimated: 1270 kg / 2800 lbs caravan around 14 cwt in third gear at 1000 rpm is would travel at 11.9 mph / 2.02 ratio of transfer box so 5.9 MPH at 1000 RPM I returned to pull another caravan stuck on the hill and only got into second low so 3.4 MPH at 1000 RPM, I started in first gear which would have given 2 MPH at 1000 RPM and I would not have liked to have started off in anything other than first low. Oh the car I used was 1962 Austin Gipsy.
The caravan I towed from standing start on the hill was being towed by a 1.3 Marina which got half way up first section, it was heavier than my caravan, no wonder he did not make it. However I am lead to under stand the towing weight is what the car can pull up a 1 in 12 which is really not that steep. So even with a permitted tow weight of 3000 kg and a caravan max weight of 1450 kg that does not mean I can pull it up any hill. I am likely to want to go through Much Wenlock and that is a 1 in 6 hill, so question is could I actually tow up that hill?
Again I have a car with a low ratio box, actually nearly the same final ratio as old Gipsy around 40 to 1, but more power around 168 BHP and diesel not petrol, wheel 17" not 16" but tyre profile means very similar however car and caravan weigh more.
So would like to be able to work it out before we try to climb any hills rather than after.
