But as you say, it's not suggested as an insulator.Hmm, I found that BS is actually advocating the use of tape.
While it does not mention using it for insulation, it does say to use it in 514.4.6
I'm not claiming that insulating tape has no insulating properties. But so does newspaper.True, but I doubt that they would even consider using 'conductive' tape, even if the joint was going to be enclosed in resin - so I presume they must have some regard for the insulating properties of whatever tape they use.
I think people have said, where insulation is needed and tape is a practical method of providing it. Over to you, please state where in BS7671 it states that insulation may not be by use of self adhesive tape wrapped around the part in an appropriate manner.Given that there are so many requirements for "insulation" in BS 7671, it is incumbent on those who say "insulating tape can be used" to say which insulating role they claim it can play.
And guess what, my mains supply is insulated with paper - OK, not recycled newspaper, but I bet there's naff all practical differenceI'm not claiming that insulating tape has no insulating properties. But so does newspaper.
And on more than one occasion I have used newspapers or cardboard as a barrier when working in live enclosures.I'm not claiming that insulating tape has no insulating properties. But so does newspaper.
I already have, and JohnW2 dismissed it as [PARAPHRASING]Not the scenario we're discussing[/PARAPHRASING].I think people have said, where insulation is needed and tape is a practical method of providing it. Over to you, please state where in BS7671 it states that insulation may not be by use of self adhesive tape wrapped around the part in an appropriate manner.
Indeed it's not.It is also not suggesting it as "not an insulator".
The problem is not that is says "tape may not be used", it's that tape does not have the properties necessarily required.I looked at the previously quoted part of BS7671, specifically 412.2.1.3 and it says nothing about tape, no mention of tape not being able to be used.
That's not using it as an insulator.I use it when running sets of wiring in trunking, when you have multiple welding bays to provide a L,N,E for to be able to distinguish which is which at any point in the trunk they have some coloured tape wrapped around them at about every 8 foot or so, different tape per set.
That sounds like Basic Insulation to me - do you agree?When taking a fitting down, the exposed end of the supply wires are taped to insulate them to prevent a numpty touching them after some other numpty has turned the power on again (I cannot always add a lock nor remove an MCB to prevent this), this has to be done as when changing a fitting I or my master may be called away to a more important issue anytime (such as a punch or press electrically breaking).
All of those other examples are not using it as an insulator.The handle on Tig welding equipment has a plastic cover over the on/off button - this is taped over to prevent it coming off or moving through constant use.
The ends of 10mm+ wires that have squash on ring terminals (ok it's actually 10mm copper pipe that's been squashed and drilled through) are likely to last longer if also given copious layers of good tape at the join.
It has multiple uses in welding bays (it must as the welders keep stealing it from the electrical dept)
Woven sleeving (high temperature polyamide I think, expands so you can add more wires through - needs heat sealing at the ends to prevent fraying) - tape can be wrapped around the ends so that it goes through holes in cabinets easier.
The ends of wire singles can be taped together so that they all go the same direction at the same time when passing them through cabinet holes etc.
This tape is general purpose and has multiple uses.
For one VERY SMALL subset of potential applications - it is a very very long way from saying that insulating tape cannot be used as insulation in the general case where it would be appropriate. I would suggest that very few of us have ever relied on 412.2.1.3 (as referred to by 412.2.1(iii) - in fact I doubt that many of us have ever relied on 412 at all.The problem is not that is says "tape may not be used", it's that tape does not have the properties necessarily required.
Indeed it's not.
Care to make any other fatuous observations, e.g. "It is also not suggesting it as 'not a nutritious snack'"?
Purposes outwith the scope of BS 7671?I'm not sure where the assertion that "that tape does not have the properties necessarily required" comes from (or what is the supporting 'evidence and proof' for it), but if it is actually true, then it begs the question as to why the Standard I recently mentioned even exists - BS EN 60454-2:2007 ("Pressure-sensitive adhesive tapes for electrical purposes"). What 'electrical purposes' could be within its scope if no 'insulating tapes' have "the properties necessarily required" - keeping the wrapping on electricians' sandwiches, perhaps?
