my garage is 5.5m x 2.8m
There is a radial circuit on the consumer unit for the garage which feeds a twin socket for the freezer and washing machine and then a single socket for the dryer at the rear of the garage, the freezer runs all the time and on wash days the washer and dryer are on together.
The consumer unit is at the front of the garage. The radial runs from there to the rear of garage back wall just above the suspended ceiling.
GE31 by mrcrow_uk, on Flickr
There is a dropped spur to a twin socket just after the consumer unit which is connected to the radial via a junction box. This is used periodically for the lawn mower, to charge my power tools and plug in a cable to a single bulb light in the void above the suspended ceiling where i store my tools and materials and need light to get them.
GE41 by mrcrow_uk, on Flickr
I propose fitting a 2Kw wall fan heater, controlled from a push type timed switch close to the laundry area so my wife can have some warm air when doing washing on cold days, and so it seems i need another twin socket in that area to plug in the heater and her iron, this would need to be further round the back wall and around 2m towards the front of the garage.
Can I extend the existing wiring from the right hand socket further to feed this new socket which will feed the fan heater and can be used at the same time for the ironing.?
GE51 by mrcrow_uk, on Flickr
All advice greatly received.
Cheers
Geof
GE31 by mrcrow_uk, on FlickrThere is a dropped spur to a twin socket just after the consumer unit which is connected to the radial via a junction box. This is used periodically for the lawn mower, to charge my power tools and plug in a cable to a single bulb light in the void above the suspended ceiling where i store my tools and materials and need light to get them.
GE41 by mrcrow_uk, on FlickrI propose fitting a 2Kw wall fan heater, controlled from a push type timed switch close to the laundry area so my wife can have some warm air when doing washing on cold days, and so it seems i need another twin socket in that area to plug in the heater and her iron, this would need to be further round the back wall and around 2m towards the front of the garage.
GE51 by mrcrow_uk, on FlickrAll advice greatly received.
Cheers
Geof
