A novice can hang and pipe up the new radiator but if you have several radiators that need exchanging consider letting a heating installer do it,make your life easy
thats a novice at work
Going to hang old radiators back on again as I got black rod out of the one it fell into!!
Will this radiator just fill back up with water again?
Also as the walls are now stud I got the anchor screws for the brackets and advice how to hung the radiators? do I just lie it flat as close to valve connections and measure the 3 brackets then replicate onto the wall?
