N
nauseous
Top Tip.We've got a roll top bath.
It's crap. Takes forever to fill, and is uncomfortable to lie in.
Fill your bath with plastic water bottles in order to have a deep luxurious bath, saves on hot water too.
Your welcome.
There is a concept in most types of tenancy contracts, more of a principle, that the landlord must "maintain" the property.This might sound mad but I need some advice. I've just had a new bathroom put in but as I rent I had no input into this. The bath that's been fitted is smaller than the previous one and as I'm not small it's not comfortable width or depth wise. Also as my son gets taller and broader, there is no way he'll be able to fit into it! What size would this bath be? What can I do?
This means that it is not just maintain as a repairing obligation context, but an obligation to maintain the type/function/specification of the things that are included in the rental.
So, a smaller bath than that fitted at the time the property was rented is a diminution of the tenancy (a lowering of the standard of that rented) and so is unlawful under typical tenancy contracts.
Tell the landlord that it is not acceptable, or see a solicitor for advice.
What does a tenant do then when the landlord is in breach of the Tenancy Agreement, brainbox?If you follow this advice expect eviction notice
Let’s look at it from a different angle the landlord has spent a few thousand on a new bathroom, the tenant then states not happy with the bath size and wants to speak to a solicitor and pretty much try and force change.
The landlord would then need to spend thousands doing that. I will guarantee you that would not happen it would be the tenant leaving that would happen.
While your advice is not wrong I am just telling the poster the likely outcome if following it which would be eviction. Your advice is like a bottle of rum it might be good but could have adverse side effects which could result in something bad happening![]()
I doubt any country has better rights than those available to UK tenants.Move to a country where tenants have better rights?
It may be that the LL was aware that the tenant required the larger sized bath but fitted a smaller one in spite. Perhaps the LL has an agenda?
Just spekulatin innit.
Thankyou. You talk sense.The Tenancy Agreement is a two way commitment with obligations and responsibilities on both sides.
No tenant should be in a postion where they feel that they can't complain about the property or tenancy. Whether it's a major or a seemingly trivial issue, any tenant should not be discouraged from complaining to the landlord. This time it's a bath, and if as you say the tenant risks eviction so should not complain, then your advice will be exactly the same for the next time ... the next faulty light switch, the next roof leak the next insecure window, then next time the heating goes out. What you are saying is no tenant should ever complain, which is wrong.
I find it odd that a landlord would specify a smaller bath. I find it more likley that the builder has just thrown a smaller bath in for one of several potential reasons.
The actual circumstances need to be determined, and that can only be once the landlord is made aware of the tenant's complaint. Then if things can't be sorted out amicably, and the issue is a landlord's obligation, the tenant has the option of doing something or nothing.
I stronglly suspect that I have seen many more L&T disputes than you have and it is not at all "likely" that tenants get evicted for complaining.The likely outcome from disputing something with a landlord which will cause them a problem is eviction I have seen this many times.
