Having our bathroom redone soon and want to insulate the room as it was freezing last winter. It's a standard two bed Victorian terrace with the bathroom on top of the kitchen at the back of the house. It measures, 2.7x3.1m. The two exterior walls are 9" brick. In his quote the builder has offered to either batten out and insulate between or go straight on with insulating board. He mentioned if we go straight on with the insulation you can get cold spots on the walls, but since we are fully tiling this wouldn't be a problem. Is there any consensus on the preferred method? What sort of board thickness should I ask for?
Futher to this we are getting electric underfloor heating. It seems insulating boarding is highly recommended. However the builder has said we he can insulate between the joists instead. We are raising the floor roughly 15cm and then he has said he will marine ply over. Should I asking to fit insulating boards on top of the ply or will between the joists do the job?
