Hi all
I have just completed my DIY alarm project and installed Pyronix Enforcer at home. I have to admit that it took me a bit longer than I expected but it was well worth it - so far not regrets.
The alarm works fine with full and part set but I still have two questions:
1) As far I know all wireless sensors are being activated only when alarm is set to preserve battery power. All my PIR sensors have a blue led on but even when alarm is not set the blue leds are being triggered when passing across the sensors. Is this expected or I’m missing something?
2) In the hope that shock sensors may deter an intruder before breaks in occur I installed contact and shock sensors (Shock-we) on all my doors and some windows. I’m wondering how the front doors shock sensor should be set up to achieve this. All my sensors are set to 06 Intruder except for the front door contact and shock 07 Final exit and hall PIR 09 ER. In this configuration the shock sensor on the front door does not trigger alarm because of entry timer. If I change it to 06 the alarm is triggered when I open the front door and it is too late to unset it. Should I adjust sensor sensitivity and leave it at 06 or maybe it should be configured in a different way? I could use a keyfob to unset the alarm before I open the front door but this is not an ideal workaround.
