- Joined
- 27 Jan 2008
- Messages
- 28,737
- Reaction score
- 3,508
- Location
- Country
OK I know basics, the head monitors air and water temperature the latter corrects the former so it shows actual room temperature and if target is higher than current it lifts the pin and if target is lower than current the pin lowers increasing or decreasing flow through valve.
However what happens in real terms? does the valve ever fully shut? or is the always a little flow? I have 4 valves with electronic heads, 3 seem to do as expected, 4th in wife's bedroom seems to have a problem, however not sure if head, base or incorrect setting, or if expecting too much.
3 valves had Honeywell bases, and one cheap base from Screwfix, cheap base in hall and that one seems to work A1, other 2 seems reasonable, only go over temperature when temperature has changed to lower value so clearly time delay, and only under temperature when again after a change or when boiler not running.
However wife's bedroom is a problem, the electronic head was fitted as she complains room too hot in the main, but some times too cold and she has piled stuff against radiator so had to assess to adjust normal TRV head, since main complaint is over temperature being able to turn radiator off remotely seemed the answer.
So this morning readings are
So with central heating off her room (Linda's bed room) does cool down, however not as much as mine (Eric's bed Room) but her room is above Living room which is set higher, so heat could raise through ceiling and floor, so latter in the day we get
where her room is much hotter than set, I have dropped hall temperature, to 19°C and her room to 12°C and swapped spacer from thick to thin in her room, to change set to 36°C and could see and hear plunger retract, on replacing set to 12°C and could hear motor run and last few seconds seemed to strain so assume is hard down, before changing spacer her radiator stayed just warm when heating running, since changing heating has hardly run, so I test bathroom radiator first with no TRV and that one has always been cold each time came to test so feeling one in bedroom pointless it will be cold as boiler not running.
So could be some thing silly like her using a trouser press, but since able to monitor her room as she had complained always seems to be too hot when heating running, so now looking at mechanical part of valve, so if radiator just warm is that a fault or normal? Could fact that her valve has been closed for a long time be a problem with poor seating, and now valve is exercised once a week at 10:30 am on a Monday will it improve.
It would be a nightmare changing valve, really hard to get to, if she was complaining of room too cold I would blame stuff around radiator, but complaint is normally room to hot.
