Yea I know it is a bad product. No display at all, nothing happens when switching on.
have checked resistance across the fan on two outer contacts and is open. When power applied there does not appear to be an active supply to the fan anyway. No attempt to ignite.
Tried two PCB's from working boilers.
The pump is free. There is power going to the PCB. No positive power to the fan or Diverter valve motor.
Happened after changing the wireless Salus thermostat but this could be a coincidence.
Pressure is OK after I decided to clean the diverter cartridge and re-pressurised. Expansion pressure is OK too.
Basically what I need to understand is what will stop everything, but power is about, and blank the display please?
As there is no display there is no troubleshooting code to work to.
Any help will be appreciated. Thanks.
