Citation ?It clearly is bad practice.
I would essentially agree, with a little qualification "...IF IT CAN BE reasonably [or 'reasonably conveniently'] AVOIDED - sisce, as you go on to say, about the only situation in which it literally cannot be 'avoided' is if lights on the circuit come with wallwarts (and, even then, some [presumably incluing Winston] might argue that they shouldn't then be powered from 6A 'lighting circuits').In Winston's defence I would say it's a poor job to add a 13amp socket to a 5amp lighting circuit IF IT CAN BE AVOIDED.
OK.No doubt the regs will change one day. They are frequently updated.
Probably the most common situation is when someone wants to have something in the loft space (aerial amplifier, other AV/IT equipment etc.) which is powered by a wallwart, and with the only wiring in the loft space being lighting circuit(s). In that situation, my personal view would be that putting a 13A socket on the lighting circuit could not be 'reasonably conveniently avoided', and I would therefore do it - but I certainly would label the socket accordingly and/or take steps to prevent the wallwart being removed 'without the use of a tool' ... and here is one "I did earlier"....
That would result in a brief moment of disappointment/frustration ("Ah, I've found a suitable place from which to feed the fire/white good/whatever ... oh no, I haven't ", but that's about all. If the nearby socket was on a lighting circuit, that almost certainly means that there are no higher-rated circuits in the vicinity - which is just a fact of life. You would presumably also regard it as being "a ****ing bastard ****" if you found that the nearest socket was an unfused spur from a ring final - but, again, that would just be a fact.It's certainly a ****ing bastard **** when in the future one is trying to fit a socket or FCU for an electric fire or a white good, only to find the nearest socket is fed with 1.0 mm2 T+E from a lighting circuit.
Such is life.Yes, but there would be some, albeit not very satisfactory, options after discovering the donor socket from the 32amp ring is a spur. Such as adding a 13 amp FCU before the two sockets.
No different than you can't plug in a cooker.Not good if other high power stuff is to be used in the original socket, but there you go.
There are a miriad of chances.There's even a chance that original socket could be got rid of, and the cable simply extended.
How could it possibly be?But I'm going off track here, and future proofing and the like isn't a reg as such.
Unless of course if everyone had the same when it would become the norm.All in all, I think most would agree it's best just to wire things as you would expect to find them, without deviating too much from the norm.
Yes, I'm sure that most people would agree that that is the 'best' approach, and I cannot imagine that anyone would feed a BS1363 socket from a 'lighting circuit' if it would be just as easy to feed it from a sockets circuit. However, I also think that many would be comfortable connecting the sort of 'dedicated' socket we are talking about (for a very small load) to a 'lighting circuit' if feeding it from a sockets circuit would involve a lot more effort/time/materials/cost/whatever.All in all, I think most would agree it's best just to wire things as you would expect to find them, without deviating too much from the norm.
AS EFLI has said, there are a myriad of possibilities.There's even a chance that original socket could be got rid of, and the cable simply extended.
