I am planning to install a double oven in the corner of kitchen.
There will be worktops either side, and the oven will be housed in a cabinet. This will obviously mean that there is a void behind the oven, and also a triangular void between the oven and the cabinets each side (concealed under the worktop).
The oven is just over 60kg, and the dimensions are H88.8cm x W59.5cm x D55cm
What would be the best way of supporting the weight of the oven, given that it it not parallel to the wall?
I don't mind losing the storage space under the oven, if the easiest thing is to support it from underneath (rather than with a wall mounted bracket).
Any thoughts would be much appreciated.
