- Joined
- 17 Oct 2005
- Messages
- 221
- Reaction score
- 3
- Country
Hi - got a Beko Condenser Tumble dryer not heating. Took back off which covers the heater , load of dust and fluff around the heating elements - removed all that. there are 2 cut out safety devices at top of heater bottom cut out device is re-settable , pushed the reset pin in and got a continuity meter put it across the bottom cut out device and it beeped the continuity meter. The top one however was open circuit and didnt beep the meter. Should this be open circuit like that? (it not a re-settable one like the bottom cut out device)
Just to get me out of trouble until I got a new heater element and just to get a load dry I shorted out the top cut out device with a piece of wire and put the terminals back onto it. But started it up and after 30seconds the 'drying' light on the front fascia panel goes from solid green to flashing green and there is no heat still.
Is there anything else I can try temporarily get it working until I can order a new heater element?
Thanks.
Thanks.
