Fit Cooke & Lewis sink base.
So if your doing something with the kitchen plumbing you can turn it off, then the wife and kids can still have a shower when you **** it up ;)
Anyone can flash a joint, that's the easy bit if you do the prep right.
Plumbing is overhyped, by overpriced plumbers.
Good! I chose the right career path then!
I am booked up to my ears with work and always will be, because even overpaid fund managers and IT geeks, who have just lost their latest cushti number still need to take a schit and a hot shower :LOL:
Buy the book and stop guessing then...
I don't need the book. It's a kitchen; when I moved in it rather fortuitously had the two traditional options of water temperature provided, each through a 15mm copper pipe (heavily referencing similar arrangements in other kitchens). Unsurprisingly, and with no assistance from any regs booklet, the old arrangement worked fine with the last sink unit, so it'll work fine with a quite minor variation in pipe positions on the next.
Go gaslight the gullible, you're wasting your valuable time here..
Go gaslight someone else.
You have missed the point being made.
In the UK, we benefit from a safe, wholesome and reliable source of potable water from the mains supply to each property (check history for cholera epidemics) and there is a reason for this... Just because something works doesn't mean its right... Suggest you look up WRAS.
The bathroom is still operational, the washing machine in that kitchen is still in use via the Heath Robinson affair that supports the various pipes. There's no lead pipework, there has been no standing water.
You’ve lost me now. I thought you were fitting a new kitchen unit and sink to some existing copper pipe.
