The cabling in my garage is all clipped directly to the walls and joists using plastic cable clips. I am going to run PVC conduit for all the cables to tidy it up and make it a bit safer. But in doing so, there are two places where the t&e currently passes through the brick wall - one feeds a PIR and the other feeds another light switch. In one instance, the cable is has been bent at a 90 degree angle as it passes into the wall. It emerges in the other side and goes directly into a PIR sensor. My question is, if the cable was inside a 20 mm pvc conduit, how can it be passed though a wall at 90 degrees? Bending the conduit will result in a radius that's too large that it will stick out..... is there a prescribed way to pass a cable through a solid wall at 90 degrees in conduit?
