    Dismiss Notice
Running T&E through a brick wall
Discussion in 'Electrics UK' started by williamglossop, 23 Dec 2018.
  1. williamglossop
    williamglossop
    28 Jan 2011
    208
    Thanks Received:
    8
    Manchester
    Country:
    The cabling in my garage is all clipped directly to the walls and joists using plastic cable clips. I am going to run PVC conduit for all the cables to tidy it up and make it a bit safer. But in doing so, there are two places where the t&e currently passes through the brick wall - one feeds a PIR and the other feeds another light switch. In one instance, the cable is has been bent at a 90 degree angle as it passes into the wall. It emerges in the other side and goes directly into a PIR sensor. My question is, if the cable was inside a 20 mm pvc conduit, how can it be passed though a wall at 90 degrees? Bending the conduit will result in a radius that's too large that it will stick out..... is there a prescribed way to pass a cable through a solid wall at 90 degrees in conduit?
  2. Sponsored Links
  3. 333rocky333
    333rocky333
    12 Jan 2008
    7,396
    Thanks Received:
    713
    Essex
    Country:
    You would tend to use a straight bit of pipe through the wall and some sort of round or square surface box mounted over the end, the cable bend being within that box
    [​IMG]
    • Thanks Thanks x 1
    • Like Like x 1
  4. flameport
    flameport
    10 Mar 2007
    8,384
    Thanks Received:
    1,550
    Poole, Dorset
    Country:
    The easy way is a 1 way conduit box with a hole in the back for the cable to pass through.
    The proper way is a 20mm hole in the back connected to another piece of conduit using a female adaptor, but that will require making the hole in the wall larger.
    However putting T&E into conduit is neither necessary or desirable, it won't make anything safer, and you are just making a pile of work for no reason.
    Unless this new conduit will be fixed with metal saddles, it won't comply with wiring regulations from January.
    • Thanks Thanks x 1
  5. winston1
    winston1
    11 Jan 2010
    5,355
    Thanks Received:
    382
    London
    Country:
    It will do if he does it by midnight Dec 31st as regs are not retrospective.
  6. williamglossop
    williamglossop
    28 Jan 2011
    208
    Thanks Received:
    8
    Manchester
    Country:
    I was gonna use metal saddles too. It just looks a bit of a mess at the mo. It'll look better in conduit.
  7. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,784
    Thanks Received:
    2,857
    London
    Country:
    And it will look even more betterer in steel conduit.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
