- Joined
- 27 Jan 2008
- Messages
- 27,997
- Reaction score
- 3,396
- Location
- Country
My modulating boiler is Bosch so only thermostat to be able to modulate boiler electrically is Wave, which does not connect to TRV heads, EvoHome and Nest will connect to TRV heads, but because Bosch has not adopted OpenTherm these will only switch boiler on/off.
I don't intend stopping in this house long, so not so worried here, but the question is how much better is a modulating thermostat? Is it really worth fitting some thing like EvoHome which can control each room independently and cools boiler down before switching it off, or is theory not as it is reported.
Reading about modulating control it says each time boiler switches off all heat in the boiler is lost through flue, so having the boiler as cool as possible before switch off is saving energy.
However that depends on at what rate of output does the boiler work most efficient. If the boilers efficiency increases as output is reduced than clearly modulating thermostats will be best, however if the reverse is true, then it would depend on switching frequency, which in turn will depend on home, so turning a boiler on for 2 hours then off for 4 hours may use less fuel than running at 1/3 maximum output. But on for 15 minutes and off for 30 minutes would reduces the hysteresis but increase losses out of flue, so in that case running at 1/3 output may work out better?
I tried reading up, however many boilers give no data, and one can't be sure the date given for one boiler is true for another.
So if starting with clean slate in new house, i.e. one which has either no central heating or a very old system, would it be really worth using a modulating wall thermostat?
