I did a job last week that should have been simple but wasn’t.
The 25mm MDPE was showing on the meter to be leaking a litre in 45 seconds.
I dug onto the pipe at the point of entry into the property 40mtrs away and capped the pipe, it still leaked.
I connected my kit which can block the pipe and fill it with air at any point and at no point did the pipe loose air pressure. Even if I didn’t block the pipe, using the meter to block it, it didn’t loose air.
I don’t understand. Could the air somehow seal a fitting that leaks water?
