Ceiling plasterboard - standard or Fireline?
19 Feb 2015
If having the ceiling plasterboard of a small 1st floor bedroom replaced I could use either standard plasterboard (£2.50 / M2) or alternatively I noticed there is a Fireline plasterboard product (£4.16/M2). The cost between these will be nominal for a small room.
Gyproc Standard Square edge Plasterboard - £2.50 / M2
https://www.diy.com/departments/gyp...board-l-2400mm-w-1200mm-t-12-5mm/35759_BQ.prd
Gyproc Fireline Square edge Plasterboard - £4.16 / M2
https://www.diy.com/departments/gyp...board-l-2400mm-w-1200mm-t-12-5mm/35764_BQ.prd
Presumably the obvious choice is therefore the Fireline poduct? Any comments? Thanks.
Just over board the ceiling with 12.5mm plaster board.
The ceiling was a lath and plaster ceiling, though with damage to the plaster. The plaster has already been removed, with the laths remaining intact. The laths are currently holding up the loft insulation.
