- Joined
- 27 Jan 2008
- Messages
- 28,338
- Reaction score
- 3,448
- Location
- Country
I can understand the idea of splitting the heating between the two areas of the house, with a timer (programmer) selecting between the two, however I can’t understand how the anti-cycle wall thermostat is deployed when splitting the output of the boiler?
Assuming no electronic TRV heads as if they were fitted then zone valves would not be required, so I would assume some way the micro switches in the zone valves will need to switch between two wall thermostats in a way where you never have both connected at the same time, as you can’t as far as I am aware fit two modulating thermostats.
I see Orange (Com) White (N/C) and Grey (N/O) wires which seem to be volt free, and integral by-pass valves built into the motorised valve, and many circuit diagrams showing how they were used before the modulating boiler and thermostat were common place. I see adverts for auxiliary switches so may be it needs these to work with two heating zones.
However the terrier i30 TRV head is just £17 and motorised valve double that and requires extra pipe work so house would need to be over 3 bedroom to ever be worth using motorised valves to split between dormitory and living area, and it would also be hard to change use of single room, be it an office upstairs or bedroom downstairs, and it would also impact on wall thermostats.
I am at the moment looking at moving, I realise valves could be energised at all times and use electronic TRV head instead, but this would I assume mean a wiring change to the wall thermostat/s.
And although central heating does not NEED a wall thermostat, without it then the user needs to decide when to turn off the system to prevent cycling, and whole idea of zone valves is automation, one could also turn radiators off/on so rather pointless unless automated.
