Had to start a new thread just to ask one final question guys as the other got closed.
The plastic light fitting as a square in square symbol as described in the earlier thread. There is no earth connection so I have added a piece of sleeve to the wire and connected it to a plastic block and parked it as advised.
Just to double check I have done the correct thing on the other end of the cable. It goes into a metal clad fused switch which does have an earth connection on the casing but I have reasoned I should not connect the earth wire to this as its not connected at the light fitting.
I have added a piece of sleeve at this end also and again connected it to a plastic block and parked it. have I done it correctly? If so that's one shed finished, and a huge thank you to all that advised me along the way.
