The only way I can run cooker hood ducting in new kitchen extension is to run through a 300mm x 300mm brick pillar that holds up a newly installed steel lintel (wall knocked through).
This rings alarm bells: the ducting should be 150mm diameter and surely I shouldn't be core drilling a hole that is half the size of the pillar?!
Tell me I am being paranoid, or even better, tell me the max diameter hole I could drill (If I can safely drill a 100mm hole then I will have to reduce the ducting diameter for that section - not a good idea for the hood, but better than the house collapsing!).
