Hi
This 40mm Floplast pipe is for compression fittings, but am I able to use it with solvent fittings too?
https://www.screwfix.com/p/floplast-push-fit-waste-pipe-white-40mm-x-3m-10-pack/18962
I was using compression fittings, but where the pipe fits to the outlet through the wall it's very tight and im not convinced a compression fittings will hold, so want to use solvent fitting on this bit.
