Cutting down small to medium trees
22 Nov 2018
Was watching some maniacs (tree surgeons) cut down these massive trees. They trimmed the branches upwards then started cutting the trunk down in bits from the top downwards. I personally do gardening and have been asked to cut smallish trees down. Is it a similar principle
Unless you have the skills and relevant insurance, forget it unless its a clear fell job.
It cost my Son fortune for climbing insurance and normal public liability wont cover you .
Smallish trees not the ones in the picture. Different totally. Bow saw at height and chainsaw at the bottom
You dont need to cut down in bits like the pictures, for small trees.
They are doing that so the short sections of trunk that are being cut are falling in a safe area. Esp important in public spaces.
If you look at the pics there is nowhere clear to fell those trees. If trees are felled or branches cut and they snag on other surrounding tree, apart from damage it creates problems with branches under tension and risk of unpredictable movement.
I cut down a 20 foot tree at my brother's house- trunk was maybe a couple of feet across at the widest. I am used to working at height .
Basically the same process- trimmed off lower branches and cut them up to save space, using the branches above as tie off points so they could be lowered down. Retain any branch "roots" so the V can used to run ropes. At some point, as you get higher, you need to tie off in the middle and cut higher branches, using the lower branches as pulleys.
Once you just have almost bare trunks you start to tie off higher trunk sections, small enough to handle, and lower them in sections.
Avoid chainsaw where you can, a sharp pruning saw can go through a thick branch, and even a small trunk. Or a bow saw as you say.
Think about what you want to do with the stump. What you save doing the tree yourself could pay for a stump grinder. Be aware of where the services might be located underground, they can be nearer the surface than you think.
Blup
Blup
I think op is doing this job for someone else Blup.
This is the size I was thinking of cutting down. Or smaller. Was going to do a chainsaw course and get all the safety equipment. Use a good bow saw for top bits. Maybe get a harness for extra safety. Chainsaw on the ground for trunk. I've heard swinging branches have swung back and broken tree surgeon's backs in past.
Reciprocating saws can also be used with a suitable blade but probably not suitable up in a tree that size. If you can get up in the branches a bowsaw will give you a good workout.
Trees can have embedded nails, grit, all sorts in them so only take on if you are fit healthy and have the right equipment.
Blup
Make a harness a 'MUST' and try to keep the restraining strap as short as possible without compromising your movements.
No point being 3 metres up a tree if your harness is 4 metres long.
If you have a clear path to fell a tree (land it on a field), would you still cut it down in sections or fell it and chop it up when on the ground?.
Anyone in particular you would recommend for medium sized trees?
