- Joined
- 7 Aug 2011
- Messages
- 100
- Reaction score
- 1
- Country
On my CU there are two switches each labelled '30a ring circuit'. I intended to move a double socket a bit higher up the wall in the kitchen so I switched off one of the circuits at the consumer unit. I tested to make sure the socket wasn't live by plugging in the kettle and it was dead. I then went to unscrew the live wires at the socket and found that one of them was still live. It would appear that one of the cables is actually connected to the second ring circuit. I have temporarily disconnected and terminated the second cable. The socket works OK but I am concerned that it only has one cable going to it now like a spur. Initially it looked like a part of the ring having two cables going to it. It's only a work top socket so it won't have to supply any real loads. I couldn't understand why the kettle wouldn't switch on and yet one of the red wires was still live. Is it best to reconnect the other cable or leave it isolated? I hope this is clear.
I forgot to say that the offending socket is the first socket wired in an extension to the kitchen.
