Hello.
I am having a double garage built.
Due to adjacent boundaries it is necessary to have cavity walls on two sides. the other two sides will be solid concrete.
To reduce costs I intend to use Thermalite, double size, blocks in the gables, or 100 mm solid concrete blocks and render them. However, Thermalite is porous, so any advice or alternative suggestions is very much welcomed.
Thank you.
Thank you.
