Sheet wood for bed base
6 Sep 2018
I would like some sheet wood to add to a bed base to make it like a divan top. What type and thickness would you recommend? Thanks
not exactly sure what you mean ??
slats are great for ventilation
something like 12mm ply with many holes drilled would replicate that
but whatever you do it will have a mattress on top so not sure off the problem :rolleyes:
I mean I want to make it so it has a solid top like a divan. I don't like slats, and we regularly air the mattress so ventilation won't be an issue. So you think plywood is a better option than mdf, our chipboard then?
chipboard and mdf are cheaper but heavier as you need to compress 4 or 5 times the now short fibres into the space to try and replicate the strength
assuming its a a say 1m wide without a center support or a wider bed with a centre support you can choose the sheet material you wish without a problem but as i say "exterior ply" tends to be best iff a bit more expensive
but keep in mind you wont have the "spring " off the slats to give coushioning so need a decent matress for other than light/young kids
Used 18mm mdf for my super king bed base , made two singles and use a sheet to lock them together on top and covered sides in cloth .
Ventilation of the under side of the mattress is essential. Water vapour from warm bodies can cause dampness in the lower layers of the mattress if there is no ventilation to disperse that vapour out of the mattress
optimist !
I was surprised in breaking up a good quality divan to ease its disposal, to find the base just used a dense thick cardboard top, with 1x2" or 1x3" wooden framework under.
Divan bases are just a basic box made as cheaply as possible , no ventilation is required, you should turn and rotate your mattress monthly to avoid dips and keep it aired.
