Order of work, patio, drainage, steps
28 Oct 2017
In the attached image I’ve tried to show the bits of additional work required as part of my patio project. Aside from the patio floor there is also an ACO drain running the length, a new gully just around the corner out of shot, a step to the back door and also a split level step up to the garden. I am wondering what is the best order to start the work in?
The ACO drain will be 1 flag away from the house.
The top step is at the same level as the grass.
The steps will be the same flag as the patio, layer on concrete blocks.
Many thanks
But measure from the desired finished ground level down to ascertain the required depth, ensuring you have allowed for the required layers and amount of cover, and the drain levels/falls.
