Running cable through last joist to drop down joist-parallel brick wall
1 Sep 2008
Bedfordshire
Every article I've read, and my onsite guide, shows methods to get through floor joists in the middle of a room. However, I can't find what best practice is when running a cable through the last floor joist before reaching the brick wall, where the gap between the two is only an inch or so.
Do you drill a hole as normal, then bend the end of the cable a pit so that when you push the cable through it bends round to reach the drop?
Or is there some other approach?
Or do you use the safe zone at the top of the wall?
Or do you just never run sockets on joist-parallel walls?
Thanks all!
I always had lengths of old solid core bonding cable (uninsulated) which was easy to bend.
I would thread it through the hole from the side next to the wall then tie the cable on and drag it back.
A pair of pin-nosed pliers come in handy. Oh, and a pair of gloves too, otherwise scraped knuckles would be a very likely outcome...
Chisel a notch across the top of the edge joist and cover with a steel plate - as in the link for the copper pipe.
So at 0.5 of the span - i.e. the middle of the room - is not permitted.
Depending on the depth of the joist you may be able to drill at a downward angle. i.e. if your joist is 6" deep drill down 2" from the top to within 2" of the bottom. This will give you a lead without having a sharp bend in the cable.
How can the middle of the room not be 0.5 of the span?
The 'centre' of the joist is generally taken to mean half the depth.
Colloquially "middle of the room" could be "anywhere but round the outside" - so in this context, anything but the joists close to the walls.
While the advice above is all sound, there is one thing not mentioned ... That the ****ing ****er ****ard builders often stick the end joists so close to the wall that you can't even see past the skirting. So you end up having to use a fishing rod* at a shallow angle (ie not far off horizontal) to even get it into the gap, and fish blind for the thin pull wire you've pushed through the hole.
* Aka, cable rods
