    Dismiss Notice
Running cable through last joist to drop down joist-parallel brick wall
Discussion in 'Electrics UK' started by Donkmeister, 7 Apr 2019.
  1. Donkmeister
    Donkmeister
    1 Sep 2008
    1,006
    Thanks Received:
    17
    Bedfordshire
    Country:
    Every article I've read, and my onsite guide, shows methods to get through floor joists in the middle of a room. However, I can't find what best practice is when running a cable through the last floor joist before reaching the brick wall, where the gap between the two is only an inch or so.
    Do you drill a hole as normal, then bend the end of the cable a pit so that when you push the cable through it bends round to reach the drop?
    Or is there some other approach?
    Or do you use the safe zone at the top of the wall?
    Or do you just never run sockets on joist-parallel walls?
    Thanks all!
  2. crystal ball
    crystal ball
    28 Apr 2004
    2,148
    Thanks Received:
    93
    Country:
    Creative drilling and a bit of chiselling and yes bend the cable
    • Thanks Thanks x 1
  3. securespark
    securespark
    11 Jan 2004
    33,785
    Thanks Received:
    1,030
    Country:
    I always had lengths of old solid core bonding cable (uninsulated) which was easy to bend.
    I would thread it through the hole from the side next to the wall then tie the cable on and drag it back.
    A pair of pin-nosed pliers come in handy. Oh, and a pair of gloves too, otherwise scraped knuckles would be a very likely outcome...
    • Thanks Thanks x 1
  4. crystal ball
    crystal ball
    28 Apr 2004
    2,148
    Thanks Received:
    93
    Country:
    A wire coat hanger is a useful tool also
  5. Donkmeister
    Donkmeister
    1 Sep 2008
    1,006
    Thanks Received:
    17
    Bedfordshire
    Country:
    Thanks both, I'll try using a bit of 6mm or 10mm to draw it through.
  6. EFLImpudence
    EFLImpudence
    7 Jul 2010
    31,031
    Thanks Received:
    3,356
    Retired to:
    Country:
    Portugal
    Not sure if you meant it literally but you shouldn't run cables "in the middle of the room".
    https://www.diynot.com/wiki/Electrics:route
    Also in OSG, I presume.
  7. EFLImpudence
    EFLImpudence
    7 Jul 2010
    31,031
    Thanks Received:
    3,356
    Retired to:
    Country:
    Portugal
    Chisel a notch across the top of the edge joist and cover with a steel plate - as in the link for the copper pipe.
  8. Sponsored Links
  9. crystal ball
    crystal ball
    28 Apr 2004
    2,148
    Thanks Received:
    93
    Country:
    Not sure what you mean?
  10. EFLImpudence
    EFLImpudence
    7 Jul 2010
    31,031
    Thanks Received:
    3,356
    Retired to:
    Country:
    Portugal
    So at 0.5 of the span - i.e. the middle of the room - is not permitted.
    • Thanks Thanks x 1
    • Like Like x 1
  11. conny
    conny
    30 Jun 2008
    11,234
    Thanks Received:
    341
    Suffolk
    Country:
    Depending on the depth of the joist you may be able to drill at a downward angle. i.e. if your joist is 6" deep drill down 2" from the top to within 2" of the bottom. This will give you a lead without having a sharp bend in the cable.
  12. Donkmeister
    Donkmeister
    1 Sep 2008
    1,006
    Thanks Received:
    17
    Bedfordshire
    Country:
    Ah, I mentioned running through joists in the middle of the room, not through the centres of joists.
    I'll be sure to define 3-d axes relative to defined datum points in future to avoid ambiguity ;):p
  13. EFLImpudence
    EFLImpudence
    7 Jul 2010
    31,031
    Thanks Received:
    3,356
    Retired to:
    Country:
    Portugal
    How can the middle of the room not be 0.5 of the span?
    The 'centre' of the joist is generally taken to mean half the depth.
  14. SimonH2
    SimonH2
    4 Nov 2010
    5,404
    Thanks Received:
    554
    Cumbria
    Country:
    Colloquially "middle of the room" could be "anywhere but round the outside" - so in this context, anything but the joists close to the walls.
    While the advice above is all sound, there is one thing not mentioned ... That the ****ing ****er ****ard builders often stick the end joists so close to the wall that you can't even see past the skirting. So you end up having to use a fishing rod* at a shallow angle (ie not far off horizontal) to even get it into the gap, and fish blind for the thin pull wire you've pushed through the hole.
    * Aka, cable rods
  15. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
