Sensor switch
11 Feb 2019
Pretty much the same, yes.
If you are wiring it with a rose and a cable down to the switch/PIR, then it needs to be 3 core & earth, 6243y.
You can of course have lights wired as 'loop at the switch', where normal 6242y cable would be fine up to the light.
Have you got a live and neutral available at the switch position?
Thanks for the replys fellas.
Apologies, you've lost me. I've only ever used 3 core & earth for 2 way wiring so am not familiar with it in this application.
I don't want a hard switch. I want the PIR to have full control of the circuitry.
Can I not just deliver Live and Neutral to the PIR, and then take a SL from the PIR and send it to the light?
Thanks again
Thanks for the replys guys.
So just to make sure.... something like this:
https://drive.google.com/file/d/1m-m-xNByFJPf1GWBhbxjJTnkGxpDwjFI/view?usp=drivesdk
Junction box to PIR:
live + neutral + earth
PIR to lamp:
SL
Junction box to lamp:
Neutral + earth
If there is any advantage to 3 core and earth I don't mind putting that in with your instruction. My small brain just doesn't understand it very well right now.
Thanks again
That only applies if you were wiring the lamp up as if it was a rose, because you need live and neutral to the switch, and switched live back up to the lamp, hence, 3 conductors.
You can indeed just run 6242y to the PIR, then another 6242y to the lamp.
