I am getting some steel stair frames installed at ground level- two stringers. I will provide the treads. The company tells me I have to proved a concrete base 400 x 400 X 200 on the ground under the floorboards at the base of each stringer . This would be about 1 metre below floor level.
Apart from me having to rip up the floorboards I am not qualified, trained or have any experience of shuttering or any other way of building concrete bases. I assume they will secure the stringers by attaching it to the block bjut how does that support the weight At the top it is drilled into the wall
I thought of hollow concrete blocks you can get from Travis Perkins and just placing them on the ground and filling them with ready mix.
I am just not sure of the method of securing the base for the steel stringers or who is responsible for providing them. Bit of advice is needed
