The spacer serves two distinct functions :
1) To fill the gap that needs to be between the CUs and trunking (equally valid with one CU) that's required in order to be able to fit the trunking lid. Without that, no chance of maintaining any pretence at IP4x - or even just the basic IP3x provided by the trunking & fittings.
2) To protect the cables from the sharp edges of the metal - the hole in the spacer is slightly smaller than those in the metal. Yes you could just put grommet strip around the hole, but ...
The spacer is quite easy to work, so by the time the metalwork is marked out etc, it's almost no effort at all to cut the spacer - in fact, I made the spacers first and (before cutting out the holes - hole saw and fret saw) used that as a template to drill holes in the metalwork. In fact, I reckon it took no more effort to make the spacers than it takes to persuade some grommet strip to fit and stay put on the metalwork edges. It really isn't all that much more work than accurately cutting matching holes for several large bushes and assembling them.
And it makes everything "quite solid". With four screws fixing each CU to the wall, and a couple in the trunking, I don't think anything is going to move in a hurry.
