insulated crimps crimping tool
15 Apr 2012
London
Never been keen on the reliability of small (1mm to 2.5mm) crimp connections.
However recently bought a HILKA ratchet crimper and was surprised to find that it only crimps on one side. I am right handed and was trying it on blue butt crimps and solid 2.5, holding the cable and crimp in my left hand it made a perfect crimp to the LHS of the crimp, but when I crimped the RHS it didn't crimp. To crimp the RHS it is necessary to turn the tool 180° and use it upside down. I have since found that two other crimping tools are the same and only crimp on one side.
Are people aware of this and does anyone know of a crimper that doesn't have the this deficiency.
If I understand correctly, yes I'm aware that one side of my crimper presses the metal part of the crimp around the wire core, and the other side squishes the plastic around the insulation. I'll admit to sometimes turning the tool upside down if access is restricted, but I normally do the other side from the other side if that makes sense.
Or -
Do the RHS first with it on the left. :)
You shouldn't really crimp solid conductors with the usual squash flat crimpers.
It's not a deficiency - its how they work.
The butt crimp requires 2 crimping actions as it is 2 crimps in one.
There is no need to turn the tool - simply turn the crimp around, do you also put a screwdriver into a screw and run round in circles? lol
Stop buying cheap nasty crimp terminals!:p:p A metal part grabs the wire insulation also in good crimp terminals...
BS 7727 sadly says it's 'optional', hence most terminals for sale are crap.
Decent quality Panduit ones...
I was considering fixed wiring, eg removing an unwanted s/o. And your analogy is daft because screws only work in one direction at a time.
The HILKA crimper was marked RYB on both sides, which I think is confusing.
Got a new crimper (unbranded) today, the new one is only marked RYB on one side, so I know the cable must always be on the RYB side.
The good news is, for both crimpers, I crimped six blue through crimps on 2.5 solid in series, held one end in a vice and pulled the other end with pliers, and couldn't pull them apart. So at least they both work, but personally I would avoid a crimper marked RYB on both sides.
