gully pipe
20 May 2019
fitted new gully but will pipe be to close to finished floor hight, it shortest route, and just clears footing as it is now View attachment 164690
Which model of gully have you used?
I can’t make out from your picture but if it’s an Osma one that can be raised up with 6” pipe then you could cut it short and glue the top on rather than having the rubber seal hold it in place.
gully finished height ok, its the pipe im worried about, once i start using wacker plate,
I can’t make out from your picture but if it’s an Osma one that can be raised up with 6” pipe .
I think most bottle gullies can be extended with 6". Problem is buying the (expensive) 6" pipe!:eek:
I keep all my off-cuts of 6". Very handy for road stop tap access (and raising gullies).(y)
I’d swap you a length for a brew!!
