White marks on bricks
29 Oct 2007
Coventry
Hi all
Could anyone tell me what would cause these white spots on the bricks?
Any advice how to get the bricks back to normal?
It appears to be on majority of the wall
The room above is a stand up shower, basin and toilet
And down stairs is a toilet and basin
We've just purchased the house, spoke to the neighbour who said its been like that for many years!
When it was built, the builders either let the bricks which they built that section of gable from or the insulation inside it get soaked and when it dried off, that's the result.
Poor site management and quality control, but they will tell you "it's natural, it will go ..... eventually". The only positive is that it's unsightly but not detrimental. Nothing will make it go either, so don't believe anyone who tells you otherwise.
"the builders either let the bricks"??
Unsure as to when it was built, so no chemical cleaner will remove it?
You can brush it off, but it'll come back. As said , probably soaking wet bricks, it will go eventually, but eventually could be a long time. Again as said not structurally detrimental, just unsightly.
I'll give it a go with some chemical cleaner
Thanks all
"Can anybody tell me how to get rid of these white spots?"
"They will go eventually"
"Been like it for ages though"
"Eventually is a long time, nothing you can do with them, don't believe anyone who tells you otherwise"
"Okay thanks, so no chemical cleaner then?"
"No"
"Okay thanks, I'll try a chemical cleaner then."
