Not thermalites, yes through bolts or similar
not wishing to derail things but wall hung toilet should be hung off a proprietary frame surely? if not I'd be just using normal rawlplugs and 100mm screws to screw a couple of lengths of timber to the wall, and strapping the loo to that. As soon as you lengthen the timber it's a longer lever so the forces will be much more reasonable.
they are lightweight aggregate blocks
The floor will take the weight - the wall just needs a plug and screw - Fischer nylon plugs are good. If the dust coming from the drilled block is black - it's a cinder block. Is your house pre 60's ?Ahh yes i forgot to mention that there is a frame for w the wc. The wc bolts to the frame and the frame bolts to the wall and floor
Thanks. i thought any type of expanding bolt might cause damage to the block or possibly crack it
Yes nige f is spot on some decent wall plugs should be enough due to the low forces. But again, if you're concerned, get a sheet of decent thick ply and fix that to the wall with more fixings, then fix the loo to the ply.Ahh yes i forgot to mention that there is a frame for w the wc. The wc bolts to the frame and the frame bolts to the wall and floor
Don't you think they look like lightweight aggregate concrete blocksIf the dust coming from the drilled block is black - it's a cinder block.
