What about toasters?
417.1 The protective measures of obstacles and placing out of reach provide basic protection only.That all obviously makes very good sense, and is certainly what I would say. However ...
I think you might have some difficulty in finding an explicit regulation, particularly given things like (same in both 17th & 18th eds of BS7671) ...
Whilst an appliance 'pushed up against a wall' may not be explicitly 'secured', one would think that its sheer weight would be enough top prevent 'unintentional removal', so perhaps within the spirit of 417.2.2 (although, in my opinion, still daft and dangerous) ?
Yes, I understand all that, and I'm sure that the relevant Standard(s) require live parts of appliances to be 'non-accessible'.John, yes the fitting of the cable between the appliance and the wall comes under BS7671 but the actual manufacture of the appliance does not. It mentions that at the very start of BS7671
They are permitted as long as the elements are surrounded by earthed metal IIRC. Lampholders with the lamp missing are also permitted.What about toasters?
What is meant by 'surrounded'? With my toasters, if one were so inclined, it would certainly be possible to touch the element with, say, a piece of metal cutlery, without also touching any earthed metalThey are permitted as long as the elements are surrounded by earthed metal IIRC.
Indeed, but I'm not sure they've adequately thought that one through (at least, in relation to the matter of this thread). AS we recently discussed, a 'skilled person' is defined in BS7671 as:417.1 The protective measures of obstacles and placing out of reach provide basic protection only. They are for application in installations,with or without fault protection, that are controlled or supervised by skilled persons.
I've had to fashion some heat shields out of aluminium foil to use in my toaster to only do one side.A photo of a toaster which will do one side, jolly useful for bagels, muffins, crumpets
There is a design flaw with this one though, the stops that prevent the sides opening too far are too low, so the very hot metal at the top edge of the sides touches the table...I've had to fashion some heat shields out of aluminium foil to use in my toaster to only do one side.
Maybe not, but often laws require the adherence to standards.The OP said the issue is now resolved, but just for general info things like EN60355 are 'just' standards, which are not law.
I would say that the situation with Part P of the Building Regs (the 'law') is exactly the same. Part P consists of just one sentence, essentially just saying that electrical work must be done safely - it certainly does not refer to any Standards or suchlike. However, Approved Document P (which is not 'law', but is meant to be guidance on compliance with Part P) makes it clear that compliance with BS7671 is one way of demonstrating compliance with Part P, but that it was not 'mandatory', nor 'the only way'.It's basically saying you have to make something that's safe and be able to prove it's safe and standards are a great way to do that, but they are not the only way and therefore adhering to them is not a requirement, simply one way to achieve the safety objectives set out in the law.
I don't have the legal knowledge to confirm or contest that statement, however I would be interested if you have some examples of where that is the case, i.e. where a law requires adherence to a standard, especially in an electrical / electronic context.
