Where is the electric going?
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
I removed the Scottish Power monitor from old house, renewed the batteries, and fitted to new house, some items are auto switching off/on so 230 to 400 watt, but not seen it hit anywhere near zero.
OK TV standby and Sky box and phone chargers but still seems high, can't access fuses so don't know which circuit and clearly switch off all power and monitor stops working.
Working through items, Sky Q repeater box 9W main Sky Q 12W to 21W trying to think what could use around 200W which I have missed.
Is this something that clips around one of the main cables ? If so, then it only measures current - and in the presence of non-linear loads (low power factor), can significantly over-read. Not to mention that the device itself may (probably has) limited accuracy at low power levels.
monitors are wildly inaccurate at low consumption levels at perhaps 200w with a stray 40-80w that isnts being consumed but registering
I have some of them. They usually read around 250-350W as a minimum, when there is stuff on standby, porch light, fridge and freezer, PC sleeping. I don't believe they are accurate at low numbers.
However, when I turn the kettle on, and/or other such appliances, the figure increases pretty accurately by 3000W, or whatever the other appliance is, so I think it is pretty accurate at higher numbers.
Mine was reading 537W. I just turned off the cooker hood and kitchen LED lights and it now reads 400W
i put the kettle on and it changed to 3240
That's what I would have thought. However, like you, I have a few, and I've been amazed at how reasonable they are seem to be even with very low loads (i.e. 10W or less).
Thank you all, had not considered them as being inaccurate, the idea was when issued it linked to Scottish Power and they adjusted bill according to your use, correcting each time meter read, however not long after fitting the supplier was changed so the internet part become redundant.
However the monitor still works, well it did once batteries were changed, I was going to compare immersion heater use with oil central heating, however no found an accurate way to measure oil used.
Last owners do not seem to be energy aware, there was not a LED lamp to be found, all quartz halogen, most now changed, and there was no thermostat on central heating, so wonder if some thing running I have not found, can hear freezer start and anything large would use more than 200 watt. Could easy be two bulbs running, the fuse box is in the ceiling so what else is hidden?
as an aside
i only use around 200w an hour [5kw a day ] day in day out for many years
total lighting around 35-50w lighting whole house like an xmass tree all leds
most other daily consumption a tv/laptop foreman grill /kettle/micro ff/seperate freezer
with washing machine and tumble around 2 or 3 times a month
also have 3 freevview boxes and often charge several high powered power tool batts [18/6ah typical] randomly but all these mean virtually no difference at perhaps a 2 or 3 %+ or- to overall consumption
and the point i am making is clamp on consumption meters can be very pointless
i dont have a clamp on meter but when they can over read by perhaps 60w and you are perhaps using 10w with 15 items on standby [eu/uk maximum permitted consumption 1w on standby]
so should be reading say sub 10w but actually reading 70-80w so can scewe consumption calculations
That's where we're going wrong...
I put the washing machine on twice a day at least....
theres only me me and i am a "clatty bugger":D
spend most off the summer in boxers in the garden enjoying the sun
only wear t shirts jeans socks and pants and wash full loads but do tumble dry and worked out it cost about 30p [2.5 units]to wash and tumble at about 1/3 to wash 2/3 to tumble
When my daughters were at home wife did 5 loads a day in WM 6-7 days a week.Changing the motor brushes was a yearly event.
