Some texecom premier elite 12-w questions
31 Mar 2019
Netherlands
Hi guys,
I got an premier elite 12-w from a friend who had never installed it. When i read about the ricochet technology i got interested and decided to install this panel to look if i could manage it. If it was within my capabilities to do so i would buy an elite 64-w. But now.i think that the 12-w might be enough for me.
So firstly i bought a pc-com cable and a flasher interface, watched en read tons of movies end forums.
I managed to flash the software from 3.06 to 4.00. installed 2 micro door contacts and 2 pir's (all ricochet) and the wired keypad.
Gave the sonsor's names with wintex and defined witch sensor will we active in night mode.
I thought the wired keypad would give a alarm sound when the alarm would be triggered. But it won't give a sound automaticly, only after a i press a key after a sensor is trigger it makes a. Alarm sound. Not very useful :)
So i have 3.question guys:
1) can i change anything in the settings so that the wired keypad will inmediately sound if one of the sensor's are activated.
2) is this panel with v4.00 sofware compatible with smartcom and connect app?
3) is this panel wih v.4.00 software compatible with LCDLP-W wireless keypad?
Thanx in advance guys, greetings from Amsterdam
Cheers,
Erkan
1 it should ( check keypad tones )
2 yes
3 probably not as the internal wireless part will be old ( check green sticker on wireless part )
Oh wow, thats a quick reply, thanx
Could yo tell me how to check the keypad tones.
Erkan
Did you check the version of the built in wireless expander, if you cant see the green sticker on the wireless half of the panel.
You saying the alarm doesn't make any noise, until you press a key after the alarm has activated?
If your smart com is version 2.x then flash panel to version 5.x
Hello,
Indeed, only alarm sound from the codepanel after pressing a key, when the alarm is activated. I do have a wireless indoor sounder, but not installed yet. I want to do that as last, when i have the system up and running.
There are 2 green stickers on the inside, one with the text v2.1.4 on it.
The 12-w panel has does not have v5 software, lastupdate is 4.00.
Version 3.1 on the wireless needed to have keypad yours is 2.1.4
Have you changed any setting via wintex ? As there a few non standard ticks e.g. Monitor hardware ?
One other thing ....this device you activated ...what area/ areas is it set for ? How are you setting the part sets ? Is it omit in part 1/2/3 or have you put the device in A,B ?
if you want the wireless keypad get a new panel 64-w.
You could buy a kit and it have a wireless keypad in and it be cheaper and you can sell the sensors off?
But you have to look at your programming, I would look at deleting the devices and defaulting the panel and starting again.
And get advice step by step for what you want?
Yes, i might have clicked a few changes :)
That's a bummer, i need to buy an 64w then. İ really need a wireless panel
I defined the pir's in the zone setup that they will not detect when the panel is in partial mode
Thanx for the advice guys, i really appreciate it!
I will start looking for a 64w panel, because the 12w does not meet my requirements.
I'll be back for advice when i have the new panel.
Cheers,
Erkan
Well ı did send a message to texecom. They are very friendly and willing to help. They found the solution for my problem. The CodePanel was adressed at adress 6.
But this old elite 12-w can only manage 2 CP's MAX.
solution was to take all adress pins on the CP down, except the pin of adress 1.
Must say i am impressed , Texecom has a great support team.
two different things being discussed, the point I was making and sparkymarka is that you need a new panel anyway for the wireless keypad to work properly,
your saying you had changed the address switches to an invalid address hence that solved your issue...….
