UPVC trim
21 Jul 2010
Weymouth, Dorset
All our UPVC windows have these ugly bits of plastic strip that covers up a narrow gap between inner wall and frame. I can see why they are used, simple and effective way to bridge the gap.
But are they really necessary?
On one of our windows I recently replaced the timber window cill and now the back edge of the board fits very close to the frame. I am thinking that some caulking will be sufficient to fill that gap without a cover strip.
The side gaps are about 5mm. Is there any reason why I cannot simply fill the gap and avoid the trim? The only reason I can think of is differential expansion rates that eventually open up the caulking.
I was in a similar situation and decided to use frame sealant. So far so good! Looks a lot better than trim
Caulk should work but it does shrink back. Based on what you describe, I would go with caulk but be careful when you apply it. Any stray caulk will become dirty after you smooth it and finish cutting in. I do not think that expansion will be an issue.
Don't use silicone, you can't paint over it. You can however paint over MS polymer sealants (CT1, Stixall, Sikaflex, etc).
on Pvc frames you can always first seal the frame both sides - and then glue the cover strips on over the top of the sealing.
on the exterior side, trim pieces will sometimes help throw water off - but how long they will remain in place is anybodies guess.
