i have one inline fan that is shared between two bathrooms with a pull cord switch in each one seperate from the light.
i would like to convert this to two seperate fans which are activated from the light switch which i would also like to move outside of the room to a normal switch instead of the ugly cords hanging down.
is it wise to reuse the inline fan and add a humidstat and time to the bathroom ceiling on the main bathroom as the vent is in zone one over the shower bath or convert both bathrooms to 12v fans or two inline fans ?
the existing fan is fed from a fused spur in the loft with two pull cords in each bathroom. i assume i can remove all of the wiring from the spur to the fan and two pull cords and conver the spur to two 3 poled fan switches and have a constant feed to the new fans and a switched live from each light switch to the new 3 poled spur which will be in the loft.
i find the inline fans quote noisey hence my interest in a 12v option or mains fed on the ceiling
i have a rcd in the fuse box but not sure if the whole house is protected as i know the bathroom needs to be rcd protected.
