D
Deleted member 174758
Not common, but I did a restaurant fit-out last year which was in a listed building and the fit-out was all hardwood with solid brass furniture, etc - in keeping with the general "feel" of the building we used slotted brass screws throughout (where the screws were visible) and every single screw head was "dressed". A minor detail, I know, but nonetheless when the client is paying out several millions it's worth getting the detail just soDid laugh at the person preferring slot heads so they can use a big screwdriver on 4 inch screws, I'm amazed they even make those these days.
We certainly nailed a lot more stuff than we do nowadays (I started in 1970) - partly because screws were a lot more expensive, especially brass and bronze ones. On rip-outs we used to remove and keep non-ferrous screws to fund the tea kitty. We also used to pilot drill a lot more than nowadays - generally with either a corded electric drill (B&D, Wolf and Stanley-Bridges were favourites), an "egg-whisk" or a Stanley Yankee Handyman 46 (pump action pilot drill). Did you realise that B&D started to manufacture electric drills in the UK in the early 1930s? Electric drills were therefore in ever-increasing use from the 1950s onwards. Stanley screwsink bits were a godsend on lower grade tasks where you needed to drill many dozens of holes (e.g. a pub bar unit) as they speeded things up considerably. Bigger size screws (#14 and above) were often driven with either a "Scotch spindle" (a massively long, heavy screwdriver which could be used in "deck screws" whilst standing up) or using a brace and turnscrew (screwdriver) bit. Electricians sometimes had a special 5in throw brace specifically designed to make driving smaller screws faster (the bigger the throw the slower the speed you can operate the brace). Smaller stuff was often handled with a Yankee screwdriver (they came in 3 main sizes) but polished work was ALWAYS screwed together using a cabinet pattern turnscrew unless you had a death wish because Yankees were prone to slipping out of the screw slot and skittering across the workpiece! This ruined the carefully done stain and polish and was a finable "offence" where I worked.I actually wonder how people got anything done before electricity, I suppose you'd use nails for most of the stuff I screw together these days.
Still the case - screws are slower and more costly than nails and always have been and flooring and stud walls are fundamentally high volume, low cost (relatively) jobs. The only difference is that these days we tend to gas or air nailYou only have to look at older floors and stud walls - everything is nailed.
