Hi all,
I'm after some help with regards to recent changes I made to the enforcer system.
For reference I have had this installed for over 2 years without issues using full set/night set daily.
I recently added area C to the mix, arming everything as per A with the exception of a garage door sensor as per my requirements.
My issue is when I come home with Area C set, the entry timer on the front door is not initiating and instead sounding the alarm.
If A/Full set is used, the entry timer on the same door contact starts without issues.
Does anyone know why the door contact would behave differently for the 2 areas? When creating area C I just added 'C' to the inputs I wanted to use and didn't mess around with the input type (as I want the door contact to behave the same in A and C).
Thanks,
Craig
Thanks,
Craig
